problem using char types with VASK library
T.W.CHARNOCK CHARNOTW at charlie.aston.ac.uk
Mon Feb 28 10:58:01 EST 1994
I am having a problem with the vask library  when I use structures
and arrays of structures containing characters.  The following short
program illustrates this:
#include<gis.h>
struct char_record
  char a;
  char b;
struct char_record char_array[2];
main(argc,argv)
int argc;
char* argv[];
  G_gisinit(argv[0]);
  char_array[0].a='a';
  char_array[0].b='b';
  char_array[1].a='c';
  char_array[1].b='d';
  V_clear();
  V_ques(&char_array[0].a,'s',3,4,1);
  V_ques(&char_array[0].b,'s',3,10,1);
  V_ques(&char_array[1].a,'s',4,4,1);
  V_ques(&char_array[1].b,'s',4,10,1);
  V_call();
this should produce a screen looking something like this:
    a      b
    c      d
when I use <enter> to move through the fields I get this:
   abcd bcd
   cd     d
for some reason it is printing the succeeding characters in the
structure, in unspecified places, arrgh.  I get the same problem if I
use the definition:
char a[1];
I can remove the problem if I seperate the variables by some dummy
variable eg:
char a;
int dummy;
char b;
this seems weird to me, any ideas what I'm doing wrong?  I'm
using gcc compiler on a SUN SPARC  under openwindows and
SUNOS 4.something.
cheers  Tom
Tom Charnock
Dept Civil Engineering
Aston University
Birmingham B7 5NJ UK
charnotw at aston.ac.uk
