problems with xdigit
Andreas Holz
holz at oi32.kwu.siemens.de
Wed Jan 5 06:18:44 EST 1994
Hello GRASS-Programmers,
I need Your help!
I followed GRASS-lists an I saw, there are
other peoples with the same problem.
Compiling xdigit on LINUX with MOTIF 1.2.2 is well,
but xdigit crashes.
The problem is located in xcolors.c in the
function make_colors_menu, the MOTIF funtion
XmGetPixmap and the Xt function XtCreateManagedWidget.
I got the foloowing error message:
X Error of failed request: BadValue(integer parameter out of range
for operation)
Major opcode of failed request: 53 (X_CreatePixmap)
Value in failed request: 0x0
Serial number of failed request: 413
Current serial number in output stream: 415
I debugged xdigid so far, and XmgetPixmap seems to return a value, but
nevertheless XtCreateManagedWidget crashes.
I'm not the only person with this problem and it is not onle a problem
of LINUX, see:
pklin at cerf.net xdigit PC 486 USL SVR4.2 with X11R5
rgp at aberfoyle.oz.au xdigit Sun OS 4.1.3 Sparc 10
Who is the developer of xdigit, xcolor.c?
Who can help us?
Are there know differences between MOTIF 1.1 and MOTIF > 1.2, esp. in XmGetPixmap?
Many Thanks...
