install problem
Santhi Kesavanathan kesavan at bubba.larc.nasa.gov
Thu Jan 27 17:49:55 EST 1994
Hi everyone,
	I am new to grass. I downloaded sun4 binaries from ftp server. I did
 everything as the in the installing binry version says.
 we have two suns
  SPARCstation10 (sunOS4.1.3 OpenWindows 3.0) 32M mem - rockola
  SPARCstation10 (sunOS4.1.3 OpenWindows 3.0) 64M mem - bubba
  and a juke box which is mounted on rockola. I also mounted bubba on rockola.
  my filsystem is like this,
rockola# df
Filesystem            kbytes    used   avail capacity  Mounted on
/dev/sd0a              15487    8998    4941    65%    /
/dev/sd0g             177007  152428    6879    96%    /usr
/dev/sd0h             165471   90122   58802    61%    /home
/dev/sd5a             960167    3605  860546     0%    /usr/filesysdb
archive              2097144       0 2097144     0%    /optical
bubba% df
/dev/sd0a              30807   10796   16931    39%    /
/dev/sd0g             870214  176233  606960    23%    /usr
/dev/sd1c             954710  679464  179775    79%    /usr2
/dev/eod0c            269685  220042   22675    91%    /mnt
arbs1:/usr2/wp        629878  409658  157232    72%    /usr2/wp
rockola:/optical     2097144       0 2097144     0%    /optical
GRASS binaries are reside in /optical/level0/grass which is in juke box.
now my 1st problem is I am able to run grass on bubba. when I try grass
on rockola it give me the follwing message,
<E021> Read disk error on file: lock, #2362 (table #0)pid 1146: killed due to swap problems in exec: I/O error mapping pages.
2nd problem: when I try d.mon and select x0 monitor on bubba it give me the
following message,
> x0
Sorry, </optical/level0/grass/dev/fifo.1a> not available
Have GRASS adminstrator check etc/monitorcap file
Can't stat /optical/level0/grass/dev/fifo.1a
Problem selecting x0. Will try once more
my 3rd problem: I also download source code and used (cat src.---) cmd as it was in the readme file I get the error:
-cpio Out of phase -get help. --and in the src dir I have
bubba% ls
?        dist += len;?        if (dist >= hc
     printf(" standard variance of y= %12.4c
  (he publoabntf(dumpfeyboard u "h: %-5g\n"c
,??  a->id, a->type, a->label?a->label:"<noc
7070034200276t11006a) {?rhh0610612605476504c
T(IGH)                                     c
T;?  ?  a->w=PNL_STRIP_WIDTH;? (a->h=PNL_STc
e.s are.s650442.sATTER->minyhar *)&lznlval c
int i;???i = angle + 0.99;??return((COLOR_Mc
ll not scan the possible minimums in order c
man
src
src.alpha
src.contrib
temsrc
tic Actuator *A_Line_info1, *A_Line_info2;?c
I think I am missing the src.graden directory.
I hope somebody could help me to solve these problems.
I also want to know is there any beginner's mannual.
I got some suggestions:
>As far as your first two problems, is the path to GRASS identical on
>the two machines?  Also, I presume the file system is mounted as
>read+write on both machines?
I have the filesystem as read+write on both machine.
But I edit GIS.sh an echo the path I got the following:
rockola% grass4.1
/optical/level0/grass/bin:/optical/level0/grass/scripts:/optical/level0/grass/garden/bin:.:/home/kesavan:/home/kesavan/bin:/usr/openwin/bin/xview:/usr/openwin/demo:/usr/openwin/bin:/usr/local:/usr/ucb:/usr/bin:/usr/etc:/usr/local/bin:/usr/bin/X11:/usr/amass/bin
sorry, pid 2085 was killed due to swap problems in exec: I/O error mapping pages
/optical/level0/grass/etc/GIS.sh: 2085 Killed
/optical/level0/grass/etc/lock /home/kesavan/.gislock 2083
sorry, pid 2086 was killed due to swap problems in exec: I/O error mapping pages
/optical/level0/grass/etc/GIS.sh: 2086 Killed
rockola%
bubba% grass4.1
/optical/level0/grass/bin:/optical/level0/grass/scripts:/optical/level0/grass/garden/bin:.:/usr2/bubba/kesavan:/usr2/bubba/kesavan/bin:/usr2/openwin/bin/xview:/usr2/openwin/demo:/usr2/openwin/bin:/usr/local:/usr/local/gnu/bin:/usr/bin:/usr/ucb:/usr/etc:/usr/local/bin:/usr/local/lib:/usr/bin/X11:/usr/lang:/usr2/arbs2:/usr2/lotus/123.v11/sun4/bin:/usr2/X11R4/usr/bin:/usr2/X11R4/usr/lib:/usr2/wp/bin:/usr2/bubba/usr/bin:/usr2/bubba/usr/lib:/usr2/bubba/usr/man:/usr2/bubba/usr/lib/ps:/usr2/mascripts/bin:/usr2/wp/wpbin:/usr2/wp/shbin:/usr/local/answerbook/bin
/optical/level0/grass/etc/lock /usr2/bubba/kesavan/.gislock 10470
I just don't get it. Is it a memmory porblem?
>I have heard of problem 3 before on some Suns.  The solution is to
>break the command into separate steps; first uncompress the various
>files which will produce a single cpio archive file.  Then un-cpio
>the archive.  This, however, requires twice the disk space.
I did try this suggestion it doesn't work.
-rw-r-----  1 kesavan  42204281 Jan 27 11:07 src.upd3.cpio
rockola% cpio -icdu < src.upd3.cpio
cpio: Out of phase--get help
thanks.
santhi.k
