Annouce: reading ArcView 2 shape files
James Darrell McCauley
mccauley at ecn.purdue.edu
Thu Apr 20 08:00:00 EDT 1995
[ Originally posted to: comp.infosystems.gis ]
[ Anyone want to write v.in.shapefile? -jdm ]
In article <3n4n4r$d73 at mozo.cc.purdue.edu> you write:
>As I promised earlier to GIS-L, I've obtained a copy of the
>ArcView Shape File format specs and written some library
>functions for programmers wanting to write conversion
>programs:
> ftp://pasture.ecn.purdue.edu/pub/mccauley/shapelib0.1a.tar.gz
>Included is documentation, sample data, and a simple
>example program which converts shape file data into a
>pseudo-GRASS ASCII vector format. If you use these
>functions to write your own conversion programs, I would
>appreciate hearing from you.
>Disclaimer: these functions only work on machines with big endian
>byte ordering, which means THEY WON'T WORK ON A PC!
>(For some unknown reason, ESRI mixes big and little endian byte
>ordering in shape files.)
James Darrell McCauley, PhD http://soils.ecn.purdue.edu/~mccauley/
Dept of Agricultural Engineering mccauley at ecn.purdue.edu
Purdue University tel: 317.494.1198 fax: 317.496.1115
