compiling new grass commands
Malcolm Williamson
malcolm at cast.uark.edu
Mon Feb 13 16:12:06 EST 1995
Hi, Marilyn & Jay
Normally this is pretty straight forward: you change the name of the program
within the Gmakefile in the source code directory, then run the command
"gmake4.1" to compile the program, and then run the $GIS/src/CMD/MAKELINKS.xxx
(where xxx = the machine architecture - sun4, dec, mips, etc.) command to link
everything.
The problem is that you picked a particularly messy program to work with. When
you run the command "s.menu" you are actually just running a shell script that
calls various programs under $GISBASE/etc/sites. Rather than taking up lots of
bandwidth, why don't you either call me or e-mail me directly to discuss
details.
> We are currently working with Grass4.1. We need to use s.menu, but we
> need to change the code slightly. We copied s.menu (source folder) to
> s.temp, and changed the code. How do we compile the new function,
> s.temp, and link it to Grass4.1.
> Thank you for any help
> Marilyn Hughes
> Jay Wright
> Rutgers, Dept. of Geography
> jjwright at gandalf.rutgers.edu
> mghughes at gandalf.rutgers.edu
Regards,
Malcolm D. Williamson - GIS Specialist E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-6159
Ozark Rm. 12 Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701
