point data from ARC/INFO
Malcolm Williamson malcolm at cast.uark.edu
Wed Jul 12 08:00:00 EDT 1995
On Tue, 11 Jul 1995, Daniel Rodriguez wrote:
> Hello,
>       What is the best way of bring in point data from ARC/INFO into
> grass 4.0 without using s.in.ascii. I need the point data to be a vector
> data set in grass. I used the v.import command by bringing in the point data
> by dlg method but does not work will.
Why not use v.in.arc on data exported from A/I using their UNGEN command?
If you need more detailed examples, check the Grasshopper archives on the
moon - the "ARC to GRASS" question has been discussed quite a bit.
Regards,
        -Malcolm Williamson
