Compilation of the new fp / no data GRASS
Olga Waupotitsch olga at diego.cecer.army.mil
Thu May 25 08:00:00 EDT 1995
In info.grass.programmer you write:
>Olga,
>We have been trying  (unsuccessfully) to recompile GRASS with the new
>fp code.  We deleted the .o files as you suggested, and ran GISGEN.
>The problem  is this: when it attempts to compile io.c from src/libes/raster
>it crashes because datetime.h is not present in our distribution.
>Any suggestion?  Perhaps you might know how we can build this file or
>point out where we can go get it.
>Thanks in advance,
>Scott
>Scott Miller
>USDA ARS SWRC
>Tucson, AZ  85719
>miller at tucson.ars.ag.gov
Hi, I don't usually read this list so please send any future problems to
me directly.
In order to fix the problem get the fp_alpha_update2.tar.Z
it has the files I forgot last time which you need for compilation
Good Luck!
OLGA
Olga Waupotitish
olga at zorro.cecer.army.mil
http://www.cecer.army.mil/~olga
tel: (217)352-6511 ext 6350
