GRASS-XMI and other Grass GUIs
Ping Jiang
jiangp at geosun.indstate.edu
Tue Jan 27 07:00:00 EST 1998
> 1. Should XMI be installed after GRASS4.1.3 or does the XMI installation
> process install GRASS4.3.1 also?
XMI should be installed after GRASS4.1.3 and in the same directory as GRASS4.1.
3
> 2. Does it work with Grass4.1.0? and Grass4.2?
Yes
> 3. Does XMI include a "decent" RGB display? ( with something
> more than 250 colors...)
XMI uses existing XDRIVER provided by GRASS4.x installation.
Regards,
Ping Jiang
