[GRASS5] Re: license issues
Bruce_Byars at baylor.edu Bruce_Byars at baylor.edu
Wed Dec 15 11:15:44 EST 1999
Non GPL'able code:
The entire r.le suite of programs including:
r.le.dist/
r.le.setup/
r.le.patch/
r.le.trace/
r.le.pixel/
SDTS code was release to CERL and GRASS.
The FIPS library is USGS and therefore should
be public domain.
r.nntool contains code from the NETS back
propogation neural network simulator.  The
neural network engine and headers were
incorporated into the tool.  Developed by NASA
and released into the public-domain.
r.out.mpeg may have applicable code that is
copyright by Berkeley.
f-tools use HEC format from WES.  No problem
as HEC tools are public-domain.
ogl3d modules use SGI libes.  Are they proprietary?
src.contrib/CERL/SGI - applicable copyrights to SGI
OpenGL.
CWU Census scripts by CWU.
/src.contrib/NMSU/WRAT - Cook College Remote Sensing
Center holds copyright?
grasslinks and grass.gdbase are copyright by the
regents of Berkeley in Ca.
g.gnuplot - gnuplot if GPL.
