[GRASS5] s.to.rast not wokring[3~
Bill Brown
brown at gomez.gis.uiuc.edu
Wed Nov 17 17:07:20 EST 1999
Markus,
s.to.rast expects category values, so you have to have the
elevations as category values (after #). It can be floating
point. This is another program that should be "fixed" to
take advantage of the new multiple attributes in sites -
add optional option such as "attribute=value" which, if given,
would look for the Nth floating point attribute for the site,
or if not given it would continue to use the category. Or if
the s.format tool I described before were available, you could
convert it with that. For now, you just have to use awk or
vi to fix the sites file.
- Bill
If you want to unsubscribe from GRASS Development
Team internal mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
length: 1535
max: 0
