[GRASS5] beta8 compilation problem
John Huddleston
jhudd at lamar.colostate.edu
Sat Aug 26 13:22:17 EDT 2000
Malcolm,
Check the shell script and see if you have carriage returns in it.
John
----- Original Message -----
From: "Malcolm Williamson" <malcolm at cast.uark.edu>
To: <grasslist at baylor.edu>
Sent: Tuesday, August 22, 2000 10:24 PM
Subject: [GRASS5] beta8 compilation problem
> I'm probably overlooking something silly, but I'm having no luck getting
> the latest version to compile under either Solaris 2.6 or 2.5. After
> running ./configure with user-owned directories defined, I run
> make install
> and get the following:
> malcolm at cast 32%>>make install
> test -d /proj/grass4.1/grass5.0 || mkdir -p -m 755
> test -d src/CMD/next_step || mkdir -p src/CMD/next_step
> UNIX_BIN=/home/malcolm SRC=`pwd` MAKE=make NAME_VER=`cat src/CMD/VERSION
> | head
> -1 | sed 's/\..*//'` GISBASE=/proj/grass4.1/grass5.0 MACHINENAME=`uname
> -n` /bin/sh src/CMD/generic/CREATE_GMAKE.sh
> sh: test: argument expected
> *** Error code 1
> make: Fatal error: Command failed for target `pre-install'
> Any ideas? Much obliged,
> -Malcolm Williamson
> CAST - University of Arkansas
> If you want to unsubscribe from GRASS Development Team mailing list write
to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
If you want to unsubscribe from GRASS Development Team mailing list write to:
