[GRASS5] CVS server: tool migration
Bernhard Reiter
bernhard at intevation.de
Mon Aug 21 08:11:05 EDT 2000
On Mon, Aug 21, 2000 at 11:18:42AM +0200, Bernhard Reiter wrote:
> Two changes are planned so far:
> - use intevation.de's hostkey even for the grass cvs ssh port
> You will probably see the hostkey changed.
It was not done. The same old ssh hostkey is still used.
> - Change the http browsing tool from
> cvsweb
> to
> viewcvs
Done. (This probably makes security problems less likely.)
Check: http://freegis.org/cgi-bin/viewcvs.cgi
Markus: The link to the current bugs file has to be:
Check: http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass/BUGS
Bernhard
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
Association for a Free Informational Infrastructure (ffii.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20000821/38e6b105/attachment.bin
