[GRASS5] Other vectors colors
fpacheco at adinet.com.uy fpacheco at adinet.com.uy
Fri Aug 18 18:13:49 EDT 2000
We don't know how -please tell me how- to add more colors to vectors
maps -red, blue, ...- then I modifyed the source code of d.vect to use
RGB. It's very simple but It works. I send to you de source code
(d.vect.rgb).
I'll modify the source code of the d.dm command to work with this comand
then my users can use it.
I'm working on a graphic interface PostgreSQL-GRASS like the d.dm and a
Visual SQL designer.  Fernando.
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20000818/cd57b6e0/d.vect.rgb.tar.gz
