[GRASS5] LANDSAT TM
Rohit nadig at web.cs.ndsu.nodak.edu
Tue Aug 8 13:03:45 EDT 2000
Greetings,
I am a grass user, and i am developing a web based interface to grass
using CORBA under GPL.
The ultimate objective is to allow the web based java applet [similar to
the grass client] to be able to access a distributed grass database.
Your suggestions/advice is welcome at nadig at web.cs.ndsu.nodak.edu
I also have another question regarding importing LANDSAT TM images into a
grass database. does anyone know how to import TM images in the BSQ
format?
The i.tape.other and i.tape.tm would work only for tape devices?
thank you,
Rohit
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
