[GRASS5] Makefile/autoconf progress! (libs as shared libraries)
Bernhard Reiter bernhard at intevation.de
Tue Aug 1 04:40:13 EDT 2000
On Mon, Jul 31, 2000 at 10:16:33AM -0400, Eric Mitchell wrote:
> I did some hacking this weekend on the Make stuff in grass,
Sounds good.
> Also, splitting grass into at least "libs" and "programs"
> will make this a lot easier, as explicit references to
> which directories contain which libraries can be dropped,
> in favor of referring to a single $GISBASE/$ARCH/lib
> directory.
> Additional thoughts? concerns? ideas?
Check out the glib, gtk+, gimp configure procedures.
They might provide additional inspiration on how to
modularize the process. Especially check the glib-config and gtk-config
programms. :)
	Bernhard
Professional Service around Free Software                (intevation.net)
The FreeGIS Project				            (freegis.org)
Association for a Free Informational Infrastructure            (ffii.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20000801/1b7e943e/attachment.bin
