[GRASS5] overwriting
Markus Neteler
neteler at geog.uni-hannover.de
Wed Dec 20 12:03:03 EST 2000
On Wed, Dec 20, 2000 at 10:13:57AM -0600, Helena Mitasova - staff wrote:
> >I don't know wether this should be considered as bug or feature, but in
> >v.db.reclass and in v.to.rast (presumably also in other modules), I get no
> >warning when I overwrite an existing map. In terms of user-friendliness, this
> >might be a problem.
> as far as I know many modules don't warn you (except r.mapcalc and some others)
> so it would be quite a bit of work to add it, but it should be done - Markus,
> maybe you should put it into the TO DO list so that developers know about it
> and as modules are enhanced/updated this feature can be added
Hi all,
this is an important issue I was already thinking to add to TODO.
Currently there is no consistency. It could be added easily to
make the module ask: "may I overwrite?" - But: In script mode
we don't want such questions (or every module needs *another* parameter
to allow silent overwriting).
I am not sure what we want:
- change modules to ask for overwriting in both interactive and command line
mode
- change modules to ask for overwriting in interactive mode, but silently
overwrite in command line mode
Comment are welcome,
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
