[GRASS5] [GRASS-bugs] Bugreport GRASS 5
mlennert at club.worldonline.be mlennert at club.worldonline.be
Tue Dec 19 07:00:57 EST 2000
On Debian, XFree3.x read XF86Config and XFree4.x reads XF86Config-4, so I'm
not sure this is a distribution problem. Isn't just a question of what version
of XFree you use ?
Moritz
> On Tue, Dec 19, 2000 at 04:38:43PM +0700, Justin Hickey wrote:
> > Hi Markus
> > Markus Neteler wrote:
> > > > bugreport: I have the repaint problem listed in the FAQ that X won't repaint the monitor when I drag a window over the monitor. I did the steps in the FAQ and my XF86Config file has the following:
> > > which Xfree are you using? Which windows Manager?
> > > Myself, the problem also persists on Xfree 4.0.1 and KDE 1/2.
> > > Xfree 4.0.1 with fvwm2 is fine.
> > > Time to investigate!
> > If you hadn't noticed, the person who reported this bug is one of my
> > colleagues.
> Hi Justin,
> yes, I have seen that.
> > We found that the problem was that Red Hat does not use the
> > XF86Config file but one named XF86Config-4 instead. Once we put the
> > backingstore fix in the other file, the problem was fixed. Perhaps your
> > system is similar?
> Aha! Please describe the Redhat version, that I can add such a note
> on the FAQ page.
> However, I have:
> xdpyinfo  |grep -i back
>   options:    backing-store YES, save-unders YES
> Do it is activated. But still this is causing problems on KDE2 (KDE1 as
> well).
> SuSe reads the /etc/X11/XF86Config.
> Yours
>  Markus
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
