[GRASS5] cygwin/windows port
Malcolm Blue mblue at nb.sympatico.ca
Mon Dec 18 23:45:02 EST 2000
Hello cygwin users.
I had some minor success with the XDRIVER running on cygwin/XFree.  I
was finally able to get a monitor started with d.mon.  Unfortunately, I
cannot yet select and draw to it, but since the errors were similar to
those from d.mon start=X#, I should be able to hunt them down.  There
are bugs in the cygwin IPC sources and libraries.  Once I have made a
bit more progress I will provide details.
I have been using the IPC messaging and currently have overwritten the
connect.c, SWITCHER.c and io.c in the XDRIVER/lib, XDRIVER/XDRIVER24 and
libes/raster.  Although there have been some discussions of the merits
of using the IPC messaging since it is not portable, I think we can get
it to work on cygwin without messing up the existing structure.  For
example, creating a CYG-XDRIVER and cygrasterlib.a (we can still use the
sources and object files that don't use fifo).  Or, now that I am
getting more familiar with IPC (which wasn't my goal when I started) and
have looked into the use of sockets a bit, I think that there may be a
couple of avenues to explore.  A few people have expressed interest in
getting this working so maybe my VERY small success will stimulate some
new discussions and ideas....
Any comments or suggestions?
Malcolm
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
