Subject: Re: [GRASS5] compiling beta10 on IRIX and CYGWIN/WIN32
Markus Neteler
neteler at geog.uni-hannover.de
Mon Dec 18 06:46:12 EST 2000
On Mon, Dec 18, 2000 at 05:52:33PM +0700, Justin Hickey wrote:
> Hi Markus
> Markus Neteler wrote:
> > the run.c seems to work fine on Linux (how to hard-test?).
> Well, the way I tested it was to go into init.sh and change
> $ETC/run $SHELL
> (at the appropriate place) to
> $ETC/run tcsh
> (I use tcsh) and gmake5, grass5 then changed it to
> $ETC/run /bin/tcsh
> and gmake5, grass5. But I guess we should try other shells to make sure
> they work as well.
Thanks for the hint.
I am using bash still without problems :-)
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
