[GRASS5] nviz
Markus Neteler
neteler at geog.uni-hannover.de
Sun Dec 17 14:52:34 EST 2000
Helena,
thanks for the hint. I have forwarded it to my student.
I feel he has a library violation somewhere.
On Sun, Dec 17, 2000 at 12:59:30PM -0600, Helena Mitasova - staff wrote:
> >nviz2.2 -q el=hoehen_test
> I am not sure whether that is a problem, but -q does not
> expect anything after it - it is supposed to open
> nviz without any data (and you can then load everything
> from e.g. your state file saved from your previous work.
> -q did not work in pre-beta10 versions, it was supposed
> to be fixed, but maybe the fix is not 100% done.
> so it should be either nviz2.2 -q
> or nviz2.2 hoehen_test
> >module: r.out.ascii
> >bugreport: dp paramater doesn't seem to work. All output ascii files
> >are integer regardless whether the source map is integer,
> >float, or double.
> I have used r.out.ascii with dp without problems in beta8 - has
> anything changed that cold have messed it up in beta10?
> (I haven't dowloaded beta10 yet, I hope to get to it next week.)
Well, it's somehow now working:
r.out.ascii m=dgm12.5 dp=7 |more
north: 5770690
south: 5768830
east: 3567625
west: 3565765
rows: 372
cols: 372
287.24 287.24 289.22 289.22 290.75 290.75 290.75 291.86 291.86 292.32 292.32
292.32 292.62 292.62 292.51 292.51 292.51 291.03
r.out.ascii m=dgm12.5 dp=1 |more
north: 5770690
south: 5768830
east: 3567625
west: 3565765
rows: 372
cols: 372
287.2 287.2 289.2 289.2 290.8 290.8
r.out.ascii m=dgm12.5 dp=3 |more
north: 5770690
south: 5768830
east: 3567625
west: 3565765
rows: 372
cols: 372
dgm12.5 is a DCELL map. However, the module wasn't changed. Very strange.
r.info dgm12.5
| Layer: dgm12.5 Date: Thu Oct 19 13:20:50 2000
| Type of Map: raster Number of Categories: 373
| Data Type: DCELL
Oh, I would be glad to have a fully working GRASS once...
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
