[GRASS5] [GRASS-bugs] Bugreport GRASS 5
bakerwl at uwyo.edu bakerwl at uwyo.edu
Sat Dec 16 16:19:57 EST 2000
Below is the result of your feedback form.  It was submitted by
 (bakerwl at uwyo.edu) on Saturday, December 16, 2000 at 21:19:57
subject: Bugreport GRASS 5
platform: Linux/Intel
vendor: Mandrake
cputype: Intel (i486, i586, pentium ...)
grassversion: I compiled the sources myself
cvsyesno: no, I got a source code package from the server
source_version: beta10
module: r.out.ascii
bugreport: dp paramater doesn't seem to work.  All output ascii files
are integer regardless whether the source map is integer,
float, or double.
compiler: gcc
REMOTE_HOST: geogpc1.uwyo.edu
If you want to unsubscribe from grass-bugs
mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass-bugs'
If you want to unsubscribe from GRASS Development Team mailing list write to:
subject 'unsubscribe grass5'
