[GRASS5] Programming manual or GIS library corrections?
William L. Baker
BakerWL at uwyo.edu
Sat Dec 16 16:30:49 EST 2000
No, Eric, I thought about making fixes, but I don't know LaTex
and I also was not sure I was right about these!
Bill B.
-----Original Message-----
Sent: Saturday, December 16, 2000 2:26 PM
To: 'grass5 at geog.uni-hannover.de'
Subject: Re: [GRASS5] Programming manual or GIS library corrections?
There's more errors than that in the programming manual. I'm sure Markus
would appreciate any corrections. Do you know LaTeX?
On Sat, Dec 16, 2000 at 02:03:43PM -0700, William L. Baker wrote:
> Hello,
> Am working on revision of r.le and not very knowledgeable about
> the grass5 revisions in general, so please excuse if I miss something
> obvious.
> I think the following are just little mistakes in the programming manual:
> 1. G_zero_raster_row is listed on p. 143 of latest (Nov.) revision of
> programming manual, but this does not seem to be the correct name.
> It seems that it is G_zero_raster_buf.
> 2. G_read_fp_range on p. 156. I think the correct order of the parameters
> is: (char *name, char *mapset, struct FPRange). The manual lists
> struct FPRange first.
> 3. p. 160 lists G_quant_truncate twice, but I think the second case
> should be G_quant_round as that one works OK in my program, and
> the description mentions rounding.
> The following may be either errors in the programming manual or maybe
> the GIS library?
> 1. G_read_raster_range is listed on p. 156, but does not work at all.
> The old G_read_range works fine for CELL, and G_read_fp_range
> works for float and double.
> 2. G_get_colors_min_max() is listed on p. 153, but does not work at all.
> This one seems useful and I don't know what the substitute would be?
> Bill Baker
> Univ. of Wyoming
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write
to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
If you want to unsubscribe from GRASS Development Team mailing list write to:
