[GRASS5] bugreport r.drain (?)
Markus Neteler
neteler at geog.uni-hannover.de
Wed Dec 13 14:57:01 EST 2000
Hi all,
while using r.drain to trace a flow through a DEM
from a given start coordinate, I found that no
output is produced (empty file with NULLs).
Does anyone have the same experience? Some month
ago I *could* get results...
Little confused,
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
