[GRASS5] Some Bugs
Eric G . Miller
egm2 at jps.net
Wed Dec 13 03:09:05 EST 2000
On Mon, Dec 11, 2000 at 12:17:34AM -0800, Eric G . Miller wrote:
> Okay, So I got around to installing libgeotiff and libgdal, so I could
> try r.in.gdal. Well, it incorrectly identifies the projection. I think
> the problem may be related to some of the projection info functions
> since I subsequently discovered all of the files I had been working with
> in a particular dataset have:
Okay, I'll refile this as a bug against r.in.gdal, since after some
futzing around, I couldn't reproduce whatever led up to my losing the
"zone" information. r.in.gdal seems to think this projection is 'll'
with WGS84 ellipsoid, but g.region -p gives:
projection: 1 (UTM)
zone: 10
datum: nad83
ellipsoid: GRS80
north: 4287336.36938346
south: 4286992.24959761
west: 702638.44204432
east: 703010.87980807
nsres: 0.39782634
ewres: 0.38876593
rows: 865
cols: 958
While I'm thinking about it; why do we have ellipsoids GRS80/grs80 etc.?
Aren't they the same? And if so, why does specifying ellipsoid=grs80
and then specifying datum=nad83 generate an error? If there's some
reason for having both upper and lowercase names for these,
can't we just "alias" the names somehow?
And to be even more of a pest. Is there something special about UTM?
why should it be handled differently than all the other projections?
Seems we should have:
XY data (unreferenced)
Unprojected (lat/lon)
Projected (projection)
I know there's a hysterical (I mean historical) reason for this, but it
would seem logical to do this.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
