[GRASS5] Misc. Module Errors
Markus Neteler neteler at geog.uni-hannover.de
Mon Dec 11 09:23:10 EST 2000
Hi Jeshua,
On Tue, Dec 05, 2000 at 05:22:02PM -0800, Jeshua Lacock wrote:
> Here are the rest of the modules that fail to compile and their error(s):
> Both "src/mapdev/v.geom/cmd" and "src/misc/m.clump" get this error:
>   /usr/bin/ld: Undefined symbols:
>   _GLOBAL_INTERRUPT_ALGORITHM
>   _gcvt
>   GISGEN failure at STEP: src/mapdev/v.geom
-> both are currently moved to unused.
> v.in.shape reported an error that it could not access malloc.h, so after copying malloc.h from "/System/Library/Frameworks/System.framework/Versions/B/Headers/bsd/sys/" to "src/include/" it only gets one error:
> /usr/src/grass/src/mapdev/v.in.shape
> make -f OBJ.powerpc-apple-darwin1.2/make.rules
> cc -g -O2   -I/usr/src/grass/src/include  -c shp2dig.c -o OBJ.powerpc-apple-darwin1.2/shp2dig.o
> shp2dig.c:807: illegal expression, found `}'
> make: *** [OBJ.powerpc-apple-darwin1.2/shp2dig.o] Error 1
Hi David :-)
> /usr/src/grass/src/mapdev/v.rmdup/cmd
> cc -g -O2   -I/usr/src/grass/src/include  -c rmdup.c -o OBJ.powerpc-apple-darwin1.2/rmdup.o
> rmdup.c: In function `killdups':
> rmdup.c:196: structure has no member named `_shortbuf'
> make[1]: *** [OBJ.powerpc-apple-darwin1.2/rmdup.o] Error 1
> make: *** [all] Error 2
Fixed. See other message.
> /usr/src/grass/src/raster/r.in.gdal
> cc  -o /usr/local/grass5/etc/bin/main/cmd/r.in.gdal OBJ.powerpc-apple-darwin1.2/main.o OBJ.powerpc-apple-darwin1.2/gbgetsymbol.o OBJ.powerpc-apple-darwin1.2/gdalbridge.o OBJ.powerpc-apple-darwin1.2/make_loc.o /usr/src/grass/src/libes/LIB.powerpc-apple-darwin1.2/libI.a /usr/src/grass/src/libes/LIB.powerpc-apple-darwin1.2/libgis.a  \
> _GBGetSymbol
> make: *** [/usr/local/grass5/etc/bin/main/cmd/r.in.gdal] Error 1
This is a problem on Irix, too. We need Frank Warmerdam for that.
> /usr/src/grass/src/raster/r.mapcalc/mapcalc
>   _drand48
>   make[1]: *** [/usr/local/grass5/etc/bin/main/cmd/r.mapcalc] Error 1
>   make: *** [all] Error 1
Fixed, please try from CVS.
> /usr/src/grass/src/raster/r.random
> _lrand48
> _srand48
> make: *** [/usr/local/grass5/etc/bin/main/cmd/r.random] Error 1
> /usr/src/grass/src/sites/s.kcv
>   _drand48
>   _srand48
>   make: *** [/usr/local/grass5/etc/bin/contrib/cmd/s.kcv] Error 1
> /usr/src/grass/src/sites/s.random
>   main.c: In function `main':
>   main.c:127: `drand48' undeclared (first use in this function)
>   main.c:127: (Each undeclared identifier is reported only once
>   main.c:127: for each function it appears in.)
>   make: *** [OBJ.powerpc-apple-darwin1.2/main.o] Error 1
> /usr/src/grass/src/sites/s.to.rast
> main.c:251: illegal expression, found `}'
> main.c:335: illegal expression, found `}'
Eric, may I ask you to check for this? You already managed something
like this (even if it is a compiler bug).
> /usr/src/grass/src.garden/answers/src.answers/raster/r.fill.dir/cmd
> c fmt_un.f -o OBJ.powerpc-apple-darwin1.2/fmt_un.o
> make[1]: c: Command not found
> make[1]: [OBJ.powerpc-apple-darwin1.2/fmt_un.o] Error 127 (ignored)
> OBJ.powerpc-apple-darwin1.2/fmt_un.o -o /usr/local/grass5/etc/fill/fmt_un
> make[1]: OBJ.powerpc-apple-darwin1.2/fmt_un.o: Command not found
> make[1]: *** [/usr/local/grass5/etc/fill/fmt_un] Error 127
Requires F77/g77 compiler.
> src.contrib/GMSL/g3d/src3d/raster/r3.mapcalc/mapcalc
>   _drand48
>   make[4]: *** [/usr/local/grass5/etc/bin/main/cmd/r3.mapcalc] Error 1
>   make[3]: *** [all] Error 1
>   make[2]: *** [all] Error 2
>   make[1]: *** [all] Error 1
Hope this helps again (it's unbelievable that you compiled this
in beta8... nothing changed.)
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
