[GRASS5] compiling beta10 on IRIX and CYGWIN/WIN32
Markus Neteler neteler at geog.uni-hannover.de
Mon Dec 11 06:47:17 EST 2000
On Sat, Dec 09, 2000 at 01:07:58PM +0100, Andreas Lange wrote:
> GRASS5.0beta10:
> IRIX:
> g.version has double \n's (fix is on the way)
O.k.
> gis_set.tcl: -state disabled instead of -state disable
Can't see that. Seems to be fixed.
> gis_set.tcl: string compare -nocase: not supported
> although this is supported from tk8.2 on, it is not
> ok to use this if we claim tk8.0 compatibility.
This might be done by Justin (hi!).
> when converting the man pages:
> many error messages with awf formatter:
> . DE not available (or such)
Hi Michel?
> g.manual from tcltkgrass:
> Illegal option -- P
> Usage: man ...
> g.manual entries=d.area -f:
> Usage:
>  g.manual .....
As g.manual is a script now, the *order* of parameters will be
important. Two possible solutions:
1. change g.manual to accept the flags at *any* place (hi Huidae!)
2. change tcltkgrass/main/gui.tcl to add flags in correct place
> this is all messed up, rman: please do not ask the user to install
> something from within Usage info. This will confuse "ordinary" users.
> CELL driver seems to work on IRIX in latlon. (colors sometimes incorrect)
> in spearfish/UTM the intermittend white lines still appear.
> r.mapcalc:
> couldn't reproduce the behaviour Anantha Prasad reported.
> This BUG is gone.
Removed from BUGS.
> The problem with the reduce/reduce conflicts on compiling
> can IMHO be ignored, as the output of the parser is parsed again
> with a C program. To my knowledge the parser is ok and
> i know of no errors.
> This is the same with r3.mapcalc.
Removed from BUGS.
> r.in.png does not work
> (r.out.png, then r.in.png with this image gives me a totally white
> raster on IRIX). r.stats says: 100% * (NULL)
Maybe we just concentrate on r.in.gdal and add the GDALlib to GRASS sources.
> r.in.tiff on IRIX:
> r.in.tiff [1591] - out of logical swap space during exec - see swap(1M)
> killed.
> argh, i have 128 MB RAM and another 128 M RAM swap.
> Must be some sort of segfault. This happens when invoking only
> r.in.tiff, without any arguments!
As far as I know Eric is working on that.
> wrong order of libs: $(MATHLIB) in
> src.garden/answers/src.answers/display/d.lingraph/cmd/Gmakefile
fixed.
> src.contrib/GMSL/g3d/src3d/raster/r3.showdspf.openGL/Gmakefile
Fixed.
> CYGWIN:
> grass5
> /usr/local/grass5/etc/Init.sh: not found
> does not start with and without any commandline flag (-text, -tcltk etc.)
> COMPLETELY BROKEN NOW!
Hi Justin! :-) Seems to be a problem in src/general/init/Gmakefile.
> GENERAL:
> g.help:
> PAGEUP/PAGEDOWN: doesn't work on every terminal.
> E. g. on IRIX it is broken.
> This needs to take the termcap into account. It is not possible
> to hardcode the keycodes into the program.
Volunteers? I have no idea about termcap, sorry.
> t.roads.inf from spearfish database is broken/wrong format.
> no cat support (informix db?)
Maybe we remove this from spearfish? It will be informix related.
> tests that i performed:
> for f in `g.mlist type=rast` ; do
>   d.erase white
>   echo "plotting $f"
>   d.rast $f
>   sleep 2
> done
> and with d.vect, d.area, d.site etc.
Sorry, can't follow. You tested all display modules by that?
Regards
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
