m.clump (was Re: [GRASS5] Misc. Module Errors)
Markus Neteler neteler at geog.uni-hannover.de
Mon Dec 11 04:23:36 EST 2000
On Sun, Dec 10, 2000 at 06:10:38PM -0800, Jeshua Lacock wrote:
> On Tuesday, December 5, 2000, at 11:20 PM, Eric G . Miller wrote:
> > > Both "src/mapdev/v.geom/cmd" and "src/misc/m.clump" get this error:
> > >   /usr/bin/ld: Undefined symbols:
> > >   _GLOBAL_INTERRUPT_ALGORITHM
> > >   _gcvt
> > >   GISGEN failure at STEP: src/mapdev/v.geom
> > Well, I think this command must be moved out of default build anyway
> > (license problem).
> Hi,
> m.clump now reports the following error:
> cc: /usr/src/grass/src/libes/LIB.powerpc-apple-darwin1.2/liboptri.a: No such file or directory
> cc: /usr/src/grass/src/libes/LIB.powerpc-apple-darwin1.2/libsos.a: No such file or directory
> cc: /usr/src/grass/src/libes/LIB.powerpc-apple-darwin1.2/liblia.a: No such file or directory
> cc: /usr/src/grass/src/libes/LIB.powerpc-apple-darwin1.2/libbasic.a: No such file or directory
> make: *** [/usr/local/grass5/etc/bin/main/cmd/m.clump] Error 1
Hi all,
m.clump is moved to /unused/misc/ now due to the dependency on
copyright restricted geom lib.
Like this the compile problem "goes away"...
(shall I upload the new detri lib?)
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
