[GRASS5] make on linux RedHat 7.0
Markus Neteler
neteler at geog.uni-hannover.de
Mon Dec 11 04:04:23 EST 2000
Hi David,
On Sun, Dec 10, 2000 at 12:46:56PM -0600, David Delorme wrote:
> #### output from make install #####
> test -d /usr/local || mkdir -p -m 755 /usr/local
.. here this line was missing:
test -d ${GISBASE} || ${INSTALL_DATA_DIR} ${GISBASE}
(Makefile line 96, added now)
> GISGEN Sun Dec 10 12:38:35 CST 2000
> GISBASE = /usr/local/grass5
> SRC = /usr/src/grass/src
> CMD = /usr/src/grass/src/CMD
> HEADER = head.i586-pc-linux-gnu
> ARCH = i586-pc-linux-gnu
> GISGEN failure: /usr/local/grass5 - directory doesn't exist
> Why does it not want to create the grass5 dir.
It will do it now (you may change your Makefile.in respectively)
> I created the dir but got error say can't create lock file or something
> like that when i try to run grass 5
This is another problem of permissions, I think. The
/usr/local/grass5 has to get write permissions for the user/root
compiling GRASS.
Hope this help
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
