[GRASS5] v.support and large datasets (gshhs from GMT)
Markus Neteler
neteler at geog.uni-hannover.de
Fri Dec 8 12:47:42 EST 2000
Hi all,
to provide a high resolution vector coastline dataset I have
converted the
G S H H S
Global Self-consistant Hierarchical High-resolution Shorelines
from Paul Wessel and Walter. H. F. Smith
(ftp://gmt.soest.hawaii.edu/pub/wessel/gshhs/).
A problem arises from v.support which doesn't run on large files (at all or
or in reasonable time, process is still running here). If you are interested
to test GRASS with a *large* vector file, I have prepared the GMT dataset
for you:
To describe it's resolution:
(From the GMT page:) The file gshhs_h.c (High resolution) is at 0.2 km, I
have converted gshhs_f.c (Full resolution) at 0.?km (no value given). So I
have converted the *full* resolution dataset gshhs_f to GRASS ASCII vector
format for you to download at:
ftp://www.geog.uni-hannover.de/outgoing/gshhs_f_grassascii.tar.gz (58MB)
-rw-r--r-- 1 neteler users 226115131 Dez 8 17:42 dig_ascii.gshhs_f
-rw-r--r-- 1 neteler users 10561544 Dez 8 17:42 dig_att.gshhs_f
-rw-r--r-- 1 neteler users 2166637 Dez 8 17:42 dig_cats.gshhs_f
You can use this lat/long world coastline dataset within "global dataset"
location which you get from here (or you define an empty world lat/long
location):
http://www.geog.uni-hannover.de/grass/data.html
Add the missing directories:
$LOCATION/dig_ascii
$LOCATION/dig_cats
and move the files into their directories (rename to gshhs_f or similar of
course). Then
v.in.ascii in=gshhs_f out=gshhs_f
v.support gshhs_f op=build
However, this takes muuucchhh time... Does anyone see a chance to speed
up the v.support topology build function? Maybe it would be useful to
add progress output (percentage) to v.support.
Regards
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
