[GRASS5] IRIX binaries....
Markus Neteler
neteler at geog.uni-hannover.de
Fri Dec 8 04:32:38 EST 2000
On Fri, Dec 08, 2000 at 03:40:18PM +0700, Justin Hickey wrote:
> Hi all
> I'm just trying to get the IRIX binaries compiled and have come across
> two modules that had errors and an error in the man page generation.
> The two modules were
> Module source code not installed: src/misc/m.clump (ignored)
> error:
> ld32: FATAL 9: I/O error
> (/usr/people/guest/grassCVS/grass/src/libes/LIB.mips-sgi-irix6.5/liboptri.a):
> No such file or directory
Hi Justin,
optri belongs to the geom lib which lives in src.nonGPL now (until the
detri lib is installed). So we have to move m.clump to src.nonGPL as well.
> Module source code not installed: src/raster/r.in.gdal (ignored)
> error:
> ld32: ERROR 33: Unresolved text symbol "GBGetSymbol" -- 1st referenced
> by OBJ.mips-sgi-irix6.5/gdalbridge.o.
> I haven't installed the gdal library so that is the error for r.in.gdal,
The module should compile without libgdal. Hi Frank Warmerdam...
> but I have no idea about the m.clump library. the liboptri.a file is
> supposed to be a grass library but apparently is not compiled (no other
> reference to it in the grass compile output.
> For the man page generation I get the following two errors for every man
> page:
> geqn:fatal error: can't open `/usr/pub/eqnchar': No such file or
> directory
> gtroff: fatal error: can't open `/usr/lib/tmac/tmac.an': No such file or
> directory
> The /usr/pub and /usr/lib/tmac directories do not exist on SGI's.
?? No idea here...
> Andreas, do you get the same error message. BTW, trying to run
> man -M /.../grass/man d.rast
> gives errors concerning "not printable man page".
> Any suggestions would be greatly appreciated.
Even no idea, sorry!
Yours
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
