[GRASS5] For users of Grass beta 10
Justin Hickey
jhickey at hpcc.nectec.or.th
Thu Dec 7 22:26:59 EST 2000
Hello all
If you are using the latest release of GRASS (beta10), you may receive
the following error message:
Error in startup script: wrong # args: should be "string compare string1
string2"
while executing
"string compare -nocase $ver "8.0""
(file "/usr/local/grass5b10/tcltkgrass/script/gis_set.tcl" line 706)
This occurs because the -nocase option to string compare is a recent
addition to Tcl/Tk, so older versions of Tcl/Tk do not support this
option. The simple fix for this error is to simply edit the file
tcltkgrass/script/gis_set.tcl and remove the -nocase option on line 706.
After this fix, grass5 should run properly.
Thank you.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
