[GRASS5] _gtty & _stty errors
Eric G . Miller egm2 at jps.net
Wed Dec 6 23:29:48 EST 2000
On Wed, Dec 06, 2000 at 08:04:13PM -0800, Jeshua Lacock wrote:
> > > I tried "cc -L/usr/include ..." and "cc -L/usr/local/include..." and
> > > both attempts reveal the same error.
> > The option is -I/path/to/includes for header files.  The -L/path/to/libs
> > is only used by the linker (ld) for libraries.
> Mmm, well the linker is what is reporting the error.  Here is an
> example copied from the shell (running gmake5):
> /usr/src/grass/src/display/d.colors make -f
> OBJ.powerpc-apple-darwin1.2/make.rules
> cc -L/usr/local/lib/ -o /usr/local/grass5/etc/bin/main/cmd/d.colors
> OBJ.powerpc-apple-darwin1.2/curses.o
> OBJ.powerpc-apple-darwin1.2/sigint.o
> OBJ.powerpc-apple-darwin1.2/set_sigs.o
> OBJ.powerpc-apple-darwin1.2/get_info.o
> OBJ.powerpc-apple-darwin1.2/interact.o
> OBJ.powerpc-apple-darwin1.2/tbl_toggle.o
> OBJ.powerpc-apple-darwin1.2/tty.o OBJ.powerpc-apple-darwin1.2/main.o
> /usr/src/grass/src/libes/LIB.powerpc-apple-darwin1.2/libdisplay.a
> /usr/src/grass/src/libes/LIB.powerpc-apple-darwin1.2/libraster.a
> /usr/src/grass/src/libes/LIB.powerpc-apple-darwin1.2/libgis.a
> /usr/bin/ld: Undefined symbols: _wborder _gtty _stty
> So wouldn't I use -L/lib/path??
That usage would be correct (not -L/path/to/headers !).
Well, I can't say for sure where that stuff is coming from on your
system.  But, I would think the symbols are actually declared in the
header files (which are processed prior to compilation to object files).
However, later the linker tries to preferentially link to a library that
has *some* but not *all* of the symbols defined by the headers and hence
the mismatch.   Try grep'ing for those symbols in /usr/include and see
which files they turn up in (possibly term.h or termios.h).
Perhaps someone with more BSD experience can be of more help.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
