[GRASS5] _gtty & _stty errors
Eric G . Miller egm2 at jps.net
Wed Dec 6 01:54:00 EST 2000
On Tue, Dec 05, 2000 at 04:07:11PM -0800, Jeshua Lacock wrote:
> Greetings listers,
> The following modules:
>   /usr/src/grass/src/display/d.colors
>   /usr/src/grass/src/imagery/i.class
>   /usr/src/grass/src/imagery/i.ortho.photo/photo.2image
>   /usr/src/grass/src/imagery/i.points
>   /usr/src/grass/src/imagery/i.points3/inter
>   /usr/src/grass/src/imagery/i.vpoints
> Report the same error:
>    /usr/bin/ld: Undefined symbols:
>    _gtty
>    _stty
Those should be defined in libncurses, I think.  Do you have the
ncurses5 library installed?  It may be the linker is not finding the
libraries correctly (maybe use the --with-libs=/path/to/libdir).  The
linker is often very limited in where it will look for thing by default,
hence all the -L/usr/X11R6/lib and similar flags.  See other post as
well.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
