[GRASS5] configure.in Wants testers...
Eric G . Miller egm2 at jps.net
Wed Dec 6 01:29:43 EST 2000
On Tue, Dec 05, 2000 at 06:07:51PM +0000, Markus Neteler wrote:
> On Tue, Dec 05, 2000 at 05:58:14PM +0000, Markus Neteler wrote:
> > On Tue, Dec 05, 2000 at 05:51:08PM +0000, Markus Neteler wrote:
> > > On Tue, Dec 05, 2000 at 05:40:51PM +0000, Markus Neteler wrote:
> > > > Hi Eric,
> > > > a report on configure... If *not* runnung autoconf, the
> > > > GISBASE             = @GISBASE@
> > > > is not expanded in head file (tested on Solaris without autoconf).
> > > > If running autoconf, it is o.k. (tested on Linux). It seems,
> > > > some code needs to be added to configure. Will you look for
> > > > that? I have added the "sed" line for GISBASE already to
> > > > get an empty variable in head file.
> > > Hi again,
> > > I have added the missing code now in "configure" (taken from an
> > > autoconf/configure run). Please check if o.k.
> > Sorry to write again.
> > On Solaris I get:
> > creating Makefile
> > sed: command garbled: s%@VERSION@%5.0beta9%g
> > creating src/CMD/head/head
> > creating src/scripts/shells/create_fifos.sh
> > creating src/include/config.h
> > On Linux it expands o.k. (with updated src/CMD/head/head.in).
> > I have no clue for that! Might be the dot forbidden in
> > on Solaris/sed?
> > If so we should remove the VERSION from configure.
> One more from Solaris:
> The NAME_VER doesn't work on SUN either:
> It is expanded to:
> NAME_VER            = -n 5
> On linux no problem.
> I propose to keep the old method to get VERSION and NAME_VER in Makefile.in
> for the beta9 release (simple revert in Makefile.in and removeal of sed
> expansion on configure[.in]). We have some more time for the stable version
> to get the new approach working.
Markus, the GISBASE needs NAME_VER to be /usr/local/grass5 by default.
I thought putting these things in configure was to easiest way to
propagate them.  As far as the "-n 5", guess the -n option to echo isn't
recognized (should still work okay without it I think).  I'm not sure
where that earlier sed problem you mention is coming from.  For the most
part, I took the sed scripts from Makefile.in verbatim.  I think it's
not too big of a deal to get these fixed up pretty quick....
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
