[GRASS5] Misc. Module Errors
Jeshua Lacock jeshua at SierraMaps.com
Tue Dec 5 20:22:02 EST 2000
Here are the rest of the modules that fail to compile and their error(s):
Both "src/mapdev/v.geom/cmd" and "src/misc/m.clump" get this error:
  /usr/bin/ld: Undefined symbols:
  _GLOBAL_INTERRUPT_ALGORITHM
  _gcvt
  GISGEN failure at STEP: src/mapdev/v.geom
v.in.shape reported an error that it could not access malloc.h, so after copying malloc.h from "/System/Library/Frameworks/System.framework/Versions/B/Headers/bsd/sys/" to "src/include/" it only gets one error:
/usr/src/grass/src/mapdev/v.in.shape
make -f OBJ.powerpc-apple-darwin1.2/make.rules
cc -g -O2   -I/usr/src/grass/src/include  -c shp2dig.c -o OBJ.powerpc-apple-darwin1.2/shp2dig.o
shp2dig.c:807: illegal expression, found `}'
make: *** [OBJ.powerpc-apple-darwin1.2/shp2dig.o] Error 1
/usr/src/grass/src/mapdev/v.rmdup/cmd
cc -g -O2   -I/usr/src/grass/src/include  -c rmdup.c -o OBJ.powerpc-apple-darwin1.2/rmdup.o
rmdup.c: In function `killdups':
rmdup.c:196: structure has no member named `_shortbuf'
make[1]: *** [OBJ.powerpc-apple-darwin1.2/rmdup.o] Error 1
make: *** [all] Error 2
/usr/src/grass/src/raster/r.in.gdal
cc  -o /usr/local/grass5/etc/bin/main/cmd/r.in.gdal OBJ.powerpc-apple-darwin1.2/main.o OBJ.powerpc-apple-darwin1.2/gbgetsymbol.o OBJ.powerpc-apple-darwin1.2/gdalbridge.o OBJ.powerpc-apple-darwin1.2/make_loc.o /usr/src/grass/src/libes/LIB.powerpc-apple-darwin1.2/libI.a /usr/src/grass/src/libes/LIB.powerpc-apple-darwin1.2/libgis.a  \
_GBGetSymbol
make: *** [/usr/local/grass5/etc/bin/main/cmd/r.in.gdal] Error 1
/usr/src/grass/src/raster/r.mapcalc/mapcalc
  _drand48
  make[1]: *** [/usr/local/grass5/etc/bin/main/cmd/r.mapcalc] Error 1
  make: *** [all] Error 1
/usr/src/grass/src/raster/r.random
_lrand48
_srand48
make: *** [/usr/local/grass5/etc/bin/main/cmd/r.random] Error 1
/usr/src/grass/src/sites/s.kcv
  _drand48
  _srand48
  make: *** [/usr/local/grass5/etc/bin/contrib/cmd/s.kcv] Error 1
/usr/src/grass/src/sites/s.random
  main.c: In function `main':
  main.c:127: `drand48' undeclared (first use in this function)
  main.c:127: (Each undeclared identifier is reported only once
  main.c:127: for each function it appears in.)
  make: *** [OBJ.powerpc-apple-darwin1.2/main.o] Error 1
/usr/src/grass/src/sites/s.to.rast
main.c:251: illegal expression, found `}'
main.c:335: illegal expression, found `}'
/usr/src/grass/src.garden/answers/src.answers/raster/r.fill.dir/cmd
c fmt_un.f -o OBJ.powerpc-apple-darwin1.2/fmt_un.o
make[1]: c: Command not found
make[1]: [OBJ.powerpc-apple-darwin1.2/fmt_un.o] Error 127 (ignored)
OBJ.powerpc-apple-darwin1.2/fmt_un.o -o /usr/local/grass5/etc/fill/fmt_un
make[1]: OBJ.powerpc-apple-darwin1.2/fmt_un.o: Command not found
make[1]: *** [/usr/local/grass5/etc/fill/fmt_un] Error 127
src.contrib/GMSL/g3d/src3d/raster/r3.mapcalc/mapcalc
  _drand48
  make[4]: *** [/usr/local/grass5/etc/bin/main/cmd/r3.mapcalc] Error 1
  make[3]: *** [all] Error 1
  make[2]: *** [all] Error 2
  make[1]: *** [all] Error 1
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
