Fwd: Re: [GRASS5] New MacOS X compilation errors
Jeshua Lacock
jeshua at SierraMaps.com
Tue Dec 5 17:45:13 EST 2000
Hi all,
> Jeshua Lacock wrote:
> > On Thu, Nov 30, 2000 at 02:18:04AM -0800, Markus Neteler wrote:
> > > Hi Jeshua,
> > > please
> > > cvs update src/display/devices/XDRIVER
> > > cd src/display/devices/XDRIVER
> > > gmake5
> > > and send the errors. Please add, if the references to
> > > > > __XErrorFunction
> > > > > __XIOErrorFunction
> > > > > __Xdebug
I got the XDRIVER compiled! I figured out what caused the problem. The XDRIVER instructions said to run ranlib *.a on the lib which is what caused the problems!
> > I just updated the entire tree and In order to compile connect.c, I had to move
> connect.c.orig to connect.c. The errors I got were a bunch of messages like
> "connect.c:73: illegal expression, found `<<'" (I have a hunch that it is checked out
> our something...).
> > I got some errors about malloc and realloc, so I deleted line 1369 in SWITCHER.c to get it
> working.
What should I do about this? Eric recommend against deleting the line, I do not now what else to do.
Thanks,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
