Fwd: Re: [GRASS5] New MacOS X compilation errors
Andreas Lange
Andreas.Lange at Rhein-Main.de
Sat Dec 2 13:09:26 EST 2000
Hi Jeshua,
I have already send an instruction on how to deal with the errors below.
Please remove the files you edited by hand _before_ updating your local
CVS copy. Otherwise you'll get the conflicts, that have to be resolved
manually, what is not what you want to do.
To repeat: remove the file connect.c, do a cvs update -dP and recompile
then with gmake5 or with make install from the top directory (like in
the instruction from Markus).
Please send the header file (src/CMD/head/head.powerpc-apple-darwin1.2)
to the list, so that we can check if the X11 libraries are included.
It is always complicated to do this sort of remote-diagnosis, i am not
familiar with BSD and Darwin/Mac OS X and i don't know which level of
expertise to expect from you. So please ask if you do not understand
something.
cu,
Andreas
Jeshua Lacock wrote:
> On Thu, Nov 30, 2000 at 02:18:04AM -0800, Markus Neteler wrote:
> > Hi Jeshua,
> > please
> > cvs update src/display/devices/XDRIVER
> > cd src/display/devices/XDRIVER
> > gmake5
> > and send the errors. Please add, if the references to
> > > > __XErrorFunction
> > > > __XIOErrorFunction
> > > > __Xdebug
> I just updated the entire tree and In order to compile connect.c, I had to move connect.c.orig to connect.c. The errors I got were a bunch of messages like "connect.c:73: illegal expression, found `<<'" (I have a hunch that it is checked out our something...).
> I got some errors about malloc and realloc, so I deleted line 1369 in SWITCHER.c to get it working.
> Here is the errors for XDRIVER/XDRIVER24:
> /usr/src/grass/src/display/devices/XDRIVER/XDRIVER24
> make -f OBJ.powerpc-apple-darwin1.2/make.rules
> /usr/bin/ld: Undefined symbols:
> __XErrorFunction
> __XIOErrorFunction
> __Xdebug
> make[1]: *** [/usr/local/grass5/driver/XDRIVER] Error 1
> make: *** [all] Error 2
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
