[GRASS5] html docs from tcltkgrass + proposal
Markus Neteler
neteler at geog.uni-hannover.de
Fri Dec 1 10:44:58 EST 2000
On Fri, Dec 01, 2000 at 01:33:29PM +0700, Justin Hickey wrote:
> Hello all
> Andreas Lange wrote:
> > I would not recommend to remove the .tcltkgrass file, as it will
> > remove all user configuration (fonts, window sizes, open windows/x
> > drivers). This is not the usual behaviour of any application i know.
> I agree.
> > If we do radical changes on the .tcltkgrass format/internals, we
> > should set up a new filename (e. g. .tcltkgrass5 ).
> Unfortunately, I would advise against this. I would suggest that writing
> a conversion script is a better way to handle this. All it requires is a
> tcltkgrass version as the first line of .tcltkgrass and a small script
> to make any necessary changes. Then when the tcltkgrass module is
> compiled, it checks for a .tcltkgrass file, checks the version, then
> performs the proper substitutions to create an up to date file. At least
> this method seems to be used in other programs I've used.
> Also, I was going to propose this later but since it has come up, I'll
> propose it now. Once we release grass 5 stable, I think we should remove
> the version number from directory names and filenames. So grass5 would
> just be grass, and grass would be stored in /usr/local/grass by default.
> The only problem I can think of is gmake5 since gmake is also the
> command for GNU make. But this is solved with a simple name change.
> A good argument for this change is our recent hassle we had with wish
> and trying to determine whether a wish8.* command was installed. The
> final solution was to simply search for wish with no version numbers
> since most installations will have wish linked to the appropriate
> command. Once the version numbers were gone, life became much easier.
> Also, the fewer places we have references to the version number, the
> easier it is to change the code when the version changes. It will also
> clean up existing code by eliminating $VERSION variables. Therefore, I
> propose we remove the version numbers from directory names and
> filenames. What do people think?
Probably this is a good proposal. Only we have to avoid confusion with
grass4.x.
> While I'm at it I will make one more proposal. Throughout the code and
> documentation, the .grassrc5 file is almost always referred to as the
> "gisrc file". Does anyone object to changing the name from .grassrc to
> .gisrc? Of course, this change will be for 5.1.
Mhhh, why not keeping the program's name within the filename?
Regards
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
