[GRASS5] Re: [GRASS-COMMIT-CVS] CVS update: grass/src/libes/raster
Markus Neteler neteler at geog.uni-hannover.de
Fri Dec 1 09:53:26 EST 2000
On Fri, Dec 01, 2000 at 01:06:02AM +0100, Andreas Lange wrote:
> Hi Eric, Hi Markus,
> very nice, it works now. Now you can even close monitors by "killing"
> them.
Hi Andreas, hi Eric,
this would be great and helpful! The behaviour changed but on KDE desktop
environment the monitor does *not* close when hitting the [x] close button
on monitor window (just nothing happens). However, after invoking another
d.* module, the monitor closes and can be restarted without problems. So
generally it seems to be o.k., but the close "button" is locked.
Using fvwm2 or whatever I expect that the monitor will close immediately. I
can try that at home. Do you have a hint to make monitors on KDE behave like
this?
> I have the fix for the typecast ready and i have nearly ready a code
> reorganization that allows to switch between fifo and ipc messages by
> compiler switch (-DIPC or -DFIFO).
> Just to announce this, so that we do not get under our feet again. I
> hope that it can wait until Saturday morning, as i will check it in
> then.
O.k., no problem. Take yout time of course.
> I'll have a look at this weird CELL driver problem too.
Thanks as well!
Regards
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
