[GRASS5] regression testing?
Andreas Lange Andreas.Lange at Rhein-Main.de
Sun Jul 30 07:56:29 EDT 2000
there are already some testing programs in the source code (e. g.
src/libes/gis/TESTS, src/libes/datetime/tests). Not a real regression
testing suite, but may be good as a starting point.
Obviously some data has to be included to do testing. Or some sort of
artificial test data should be created.
What about dejaGNU? Could this be used for providing a test framework?
cu,
Andreas
James Cameron wrote:
> Is there a regression testing suite for Grass that can be run following
> compilation to verify minimum functionality?
> James Cameron    mailto:quozl at us.netrek.org     http://quozl.netrek.org/
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
