[GRASS5] Severe bug in r.mapcalc!!
[raghavan@media.osaka-cu.ac.jp: Bugreport GRASS 5]
Markus Neteler
neteler at geog.uni-hannover.de
Fri Jul 28 12:48:11 EDT 2000
On Fri, Jul 28, 2000 at 09:59:15AM -0500, Bill Brown - staff wrote:
> r.mapcalc test=-129
> This works OK on my IRIX machine. As with other negative
> numbers, it's stored using a full 4-byte int (in cellhd file,
> "format: 3"). Do other negative numbers work OK?
Thanks for testing. Obviously yes (on Linux):
r.mapcalc test=-128
EXECUTING test = ... 100%
CREATING SUPPORT FILES FOR test
range: -128 -128
-> o.k.
GRASS:~ > r.mapcalc test=-129
-> NULL!!!
GRASS:~ > r.mapcalc test=-130
range: -130 -130
-> o.k.
This is a very strange error.
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
