[GRASS5] GRASS 5 beta8 tagged! Please build binaries now
Bernhard Reiter
bernhard at intevation.de
Thu Jul 27 04:40:12 EDT 2000
On Wed, Jul 26, 2000 at 10:59:08PM -0400, Eric Mitchell wrote:
> James Cameron wrote:
> > I just wish there was a way on this end of my 56k modem to do a CVS
> > update to a tag revision and still be able to track the changes after
> > I have done a build. Possible?
> If you want to track the HEAD (default) branch, do a:
> setenv CVSROOT [whatever goes here]
> cvs -z3 co [module]
> When you want to update to the latest, change to the
> top checked out directory and:
> cvs -z3 update -dP
> The -z3 flag tells cvs to use compression on the data stream.
> -d means create new subdirectories, -P means removed otherwise
> empty subdirectories. The update command itself only retrieves
> files that have been changed since your last update.
You can try -z6 if your modem line is really slow.
Once you have a CVS checked out, it depends on how much changes.
For small changes you might be able to track and download it
using your modem line. :)
Bernhard
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
Association for a Free Informational Infrastructure (ffii.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20000727/31a6776a/attachment.bin
