[GRASS5] make vs make install
James Cameron
quozl at lisp.com.au
Thu Jul 27 00:44:17 EDT 2000
The convention is that "make" does compilation work, and that "make
install" does the copying of files into the place they are meant to go.
Packaging is normally done without running the compiler as root.
Would it be possible to fix the Grass Makefile so that this convention
is kept?
I may have mentioned this before, I don't know.
James Cameron mailto:quozl at us.netrek.org http://quozl.netrek.org/
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
