[GRASS5] -fwritable-strings
Michel Wurtz - ENGEES/CEREG
mw at engees.u-strasbg.fr
Wed Jul 26 07:00:51 EDT 2000
Bernhard Reiter wrote:
> It has nothing to do with GNU/Linux.
> Only with old programs doing stuff like:
> char * x="Heino";
> x[2]='o';
> Because the compiler with place &x in protected memory which is not
> writable usually.
Yes, the correct declaration should be :
char x[]="Heino";
because the variable you can modify is yet the character table, and
not the pointer to a static chain.
It should be easy to upgrade, unless you do something like
x = "another chain";
further in the program... In this case, x must be a pointer and the
first declaration should be used (char *x;) !
Michel Wurtz ENGEES - CEREG
1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
Tel: +33 03.88.24.82.45 Fax: +33 03.88.37.04.97
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
