[GRASS5] -fwritable-strings
Bernhard Reiter
bernhard at intevation.de
Wed Jul 26 05:02:33 EDT 2000
On Wed, Jul 26, 2000 at 03:32:18PM +0000, Justin Hickey wrote:
> On Jul 26, 9:53am, Markus Neteler wrote:
> > I am not shure. The old ps.map did not work without
> > -fwritable-strings.
> > Further suggestions are required...
> How about writing a script to be run after is64bit.sh that will check if the
> machine is Linux (the ${SYSTEM} variable in Makefile.in maybe) and then add
> -fwritable-strings to the compile lines of the Gmakefiles of ps.map? At least
> it would be a quick fix until someone can fix the problem in ps.map. Just a
> suggestion.
It has nothing to do with GNU/Linux.
Only with old programs doing stuff like:
char * x="Heino";
x[2]='o';
Because the compiler with place &x in protected memory which is not
writable usually.
Bernhard
Professional Service around Free Software (intevation.net)
The FreeGIS Project (freegis.org)
Association for a Free Informational Infrastructure (ffii.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20000726/3cd698ac/attachment.bin
