[GRASS5] ring routines revisited
David D Gray ddgray at armadce.demon.co.uk
Wed Jul 12 15:01:31 EDT 2000
Developers
In a recent posting I proposed to adjust the routines
Vect_get_area_points() and Vect_get_isle_points(). In place of that I
have now uploaded two similar routines Vect_get_unique_area_points() and
Vect_get_unique_isle_points(), which produce a ring from the exterior
boundary edges of a polygon, but without duplicating the points at the
junction.
The old routines are still there. However I can't think of any good
reason why the junction points (at nodes) should be duplicated in a
ring, so unless anyone knows of a routine that specifically needs that
feature, the old routines could be deleted, and the new ones renamed
(only v.out.shape depends on the new routines so far).
David
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
