[GRASS5] GRASS and LGPL
Andreas Lange
A.C.Lange at GMX.net
Fri Jul 7 14:54:23 EDT 2000
Hi GRASSdevelopers,
i agree with Bernhard. The required parts of the libararies should be
made available under LGPL, but only those parts that are absolutely
required. We should bear in mind what consequences loosening the
copyright could have.
cu,
Andreas
Bernhard Reiter wrote:
> However I believe that we should make the libraries which deal with
> interoperabilty available under LGPL. Frank want access to the GRASS
> data file structures, we should seperate that part of the GRASS
> libraries and release it under the GNU Lesser General Public License
> (LGPL).
> And of course we all know that Frank Warmerdam's intentions are good and
> he is a great contributor to free software. Frank: Can you identify the
> library (parts) of GRASS, you need for accessing grass files? It should
> be as small as possible. We should to get consensus to release this part
> under LGPL.
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
