[GRASS5] s.to.rast, v.bubble updated, new G_readsites
Markus Neteler neteler at geog.uni-hannover.de
Thu Jul 6 15:05:43 EDT 2000
Dear developers,
I have updated
 - s.to.rast: added attribute field selection parameter
 - v.bubble:  added attribute field selection parameter
and started to write a new G_readsites library function:
src/libes/gis/readsites.c
It is based on Job Spijker's v.bubble/support.c.
The v.bubble already makes use of G_readsites.
The idea of G_readsites is to replace the local
read_sites routines within sites modules by this
new library function. Please make use of it and,
if required, improve it! A todo section is already
included in src/libes/gis/readsites.c
You can specify the field to use for operation now
in s.to.rast and v.bubble. Next to update is s.to.vect.
Cheers
 Markus
Dipl.-Geogr. Markus Neteler *  University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494  Fax: -3984
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
