[GRASS5] v.out.e00 is ready
Michel Wurtz - ENGEES/CEREG
mw at engees.u-strasbg.fr
Fri Jun 16 09:26:13 EDT 2000
Dear Markus (and others),
After two long night, I finaly have something that mimics (as far
as I know) the e00 format. The boring thing was to create the
"universe" polygon beloved by Arc/Info.
I would be glad if some Arc/Info owner can test the output.
I something doesnt work, I will like to have an original e00
file of a simple drawing (2 polygons, on with a hole, and an
external isle) with straigth lines, so it's easy to import and
export and to compare both.
v.out.e00 use the Grass dig_att file for filling the attribute of
the coverage-ID, so if it is linked to an external database via the
attribute, you should get all of them in Arc/Info.
Here is the program, the Gmakefile and the manual page in html.
Michel Wurtz ENGEES - CEREG
1, quai Koch - BP 1039, F-67070 STRASBOURG cedex
Tel: +33 03.88.24.82.45 Fax: +33 03.88.37.04.97
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20000616/a3fb2626/v.out.e00.obj
