[GRASS5] Re: src/mapdev/v.out.shape/gen2shp-0.2.3/makefile
Markus Neteler
neteler at geog.uni-hannover.de
Thu Jun 8 10:38:34 EDT 2000
Hi Frank and John,
the "makefile" is removed now as Gmakefile from John does
the job.
Thanks for notifying.
Markus
On Thu, Jun 08, 2000 at 03:00:59PM +0200, Frank Koormann wrote:
> John,
> * John Huddleston (jhuddles at rocky.itc.nrcs.usda.gov) [000608 14:41]:
> > Frank, (Cc to grass)
> > I noticed you updated the makefile for the gen2shp directory.
> > I updated the Gmakefile so that it correctly writes out to the
> > GISBASE directory. It no longer calls makefile but rather
> > uses the standard make process per gmake5.
> Hmm. I had not updated it personally. OK, I will coordinate
> with Markus to update the Gmakefile.
> Regards,
> Frank
> Frank Koormann http://intevation.net/~frank/
> Professional Service around Free Software http://intevation.net/
> FreeGIS Project http://freegis.org/
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Dipl.-Geogr. Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
